8800GT - Strange Noise
EddieTO
Thanks for the tutorial :p The sloppy job on the stock thermal paste is an understatement LOL.
Looks like it`s goodbye horrrible stock EVGA heatsink. Hello Arctic Accelero S1 hehe. I`m not sure if the memory heatsinks that came with the S1 will stick indefinately. I should probably buy some thermal compound that doubles as an adjesive. I think Ì`m going to have to remove the 12cm fan on the door of my antec 900 and reposition it to the drivebay to blow over the card front to back.
Voodoo
Member
DeBary, FL
That looks like a very nice cooler. I've also heard good things about using the dual orb on the 8800GT as well.
EddieTO
I installed the Zalman VF900 instead of the S1 on my 8800GT since it doesnt interfere with the side-mounted fan on the antec900. The S1 is way too tall.
40degrees idle, 59 load. OMG (and the AS5 hasnt been broken in yet)
my card used to idle at 55 and go above 80 under load
Breathless
New member
I have made a video documenting this strange high pitched noise problem. In my case, it was caused by my Tagan BZ-900 power supply. I also have an 8800GT
Here is proof of my issue:
