Gallery 9900k Lian Li Pc-O11 Dynamic Build
danmitch1
Ok, big cry baby here...
I just played some battlefield 5 for the first time on this machine for about an hour and Holy lifting sh*t! its soo smooth is distracting !
I ran it on maxed out settings running 2k 60hz and only hit 62 on one of the threads, kept a steady 4.7 ghz mind you, but the cpu usage seems to have only averaged mid 80%.
In 10 years ill see if I need to Oc it, by then they will have some crazy cooler available to tame it.
danmitch1
Installed my replacement sp120's and now have my h55 sandwich back with the peace and quite that comes along with them (that h55 stock fan is so loud).\
I would say its not finished though as in the (hopefully) near future I would like a second 1080 ti and maybe even a custom loop in a few years.
Coach
Morden MB
Hmmm, are you sure the games you play support SLI? I thought multi card setups were a bad idea these days...?
Lysrin
Nova Scotia
OK, have to ask, what's the story on the plastic container feet? Increased air flow attempt to the bottom of the case? If so does it actually affect temps?
danmitch1
Well, its more to raise the case up so that I can see the top case fan rgb's better. Another use was for air flow but to be honest It doesnt make a difference!
I do agree, I need to find something nicer to raise the case with...
Lysrin
Nova Scotia
Well, I didn't say anything about nicer, but it might take a little away from your otherwise slick looking build! :biggrin:
danmitch1
Lol, Ill try and find some corsair Tupperware !
I am doing a bit of a disservice to the pc by propping it up with plastic containers, sorta like putting, i dont know, KIA hubcaps on a Lambo !
I suppose ill have to head to home depot and find something more suitable :)
