a line going across my Monitor
Shadowmeph
Not sure if it is my Monitor ( actually a LCD tv 27") or if it is my Video card, over the past 3 weeks when I wake up my PC I sometimes get a line going across the lower park of my Monitor, I checked the cables ( DVI) to make sure that they are secured which are if I reboot my PC most of the times the problem goes away but sometimes it will reboot and the line will remain for a minute or two.
Any Ideas?
moocow
Vancouver, BC
I would try a new cable first then move on to video card. I had similar issue with a hand me down Asus ProArt using my old DVI cables. The screen would flicker a bit until I replace it with a DP cable. The same DVI cable was moved to my secondary monitor and have the same behavior.
Shadowmeph
aw I can't believe I didn't think of that thanks will give that a try :)
