a rebuild. plz critique..............
rob123
the system is being built with some parts from current system and some new.
new parts are
EVGA Nforce 750I SLI Ftw LGA775 mainboard
Intel Core 2 Quad Q8200 with stock cooler
2 X bfg 8800gt oc 512 mb
8 gig OCZ Gold XTC PC2-6400 4GB 2X2GB DDR2-800 CL5-5-5-18 DDR2
used parts ( approx 1 year old) are
PC Power & Cooling Silencer 750 Quad 750W ATX V2.2 EPS12V 24PIN SLI Active PFC Power Supply Black
2 X seagate 7200.11 500 gb hdd
pioneer dvd burner
plus a coolermaster case ( great big tall thing) and the usual assortment of fans
the monitor is a samsung 25.5"
i believe he only cares about being able to play crysis maxed out. he likes world of warcraft but i think this system is far more than he needs for that. his money i guess.
tha again
rob123
Eagle Eye
Kleinburg, ON
Loose the quad and go with a good dualcore within the same price range look at the E84, 85 or 86 being the most expensive. I highly recommend getting an aftermarket cooler it will keep that quad or a dualcore nice and cool and if at some point and "he" decides to overclock he'll be able to.
Loose the nVidia chipset and get an Intel chipset find something in the same price range look at the Asus P5Q series or Gigabyte whichever best suit your needs.
2 X 8800GT's huh I think for about the same price you probably get a single 4870, adding a second later for crossfire is always option. Even with the dual 8800GT he won't be gaming at 1920x1080 I can atest to that.
8 gigs of ram? A little overkill 4gig is more than enough I highly suggest the Mushkin Ascents 2x2gigs PC8500 its also leaves alittle room
Powersupply is a great one
HDD more than enough
Case is a personal choice imo
Monitor is fine
Good luck hope I could help,
EE
Monitor is fine
miggs78
Calgary, AB
Exactly what he said.. an E8400 with an Asus P5Q Pro (if you're on a budget, you could look at the P5Q-E and P5Q Deluxe too) would be faithful enough for you.
Accompanied with a 4870 card will make a good pc for you.
4GB is more than enough, 8GB is really overkill. If your looking to overclock, get the Mushkin Ascents instead, those are really good, might be a little pricey depending on budget but I look at it as the best bang for the buck for overclockers memory..
That Power Supply is one of the best 750w PSU's out there. I'm guessing you meant you have the power supply, hard drives and case in possession. Which case is it if I may ask? :p
miggs78
Calgary, AB
Old School style and a very good case, it was the one that brought CM success in the first place.
