Babrbarossa
Today I put another 120mm LED fan into my p180, along with a blue cathode-- I piggybacked them both into the power connector up near the front which already had a couple og things on it, and when I turn it on, the cathode only lights up half-way, and the fan doesn't start on its own on the low setting (three setting switch). I assume that there must not be enough juice to run those few thing plugged in there -- is that the problem? if so, I can't seem to find anywhere else to plug it in. the excess wiring is stuffed behind the psu and I don't want to have to remove it if I don't need to-- I'm not sure if there are more connectors back in there anyway.
