I have an i3 Acer Veriton kicking around that I wanted to throw a double slot GT 1030 onto, but the original case only supports a single slot card so I figured I'd print off something I can migrate it to which would support a dual slot vid card.
www.thingiverse.com
That's the motherboard model try I'm working off of. It's wider than I need so I cut it down a bit, the support holes were too large (appropriate metric screws wouldn't fit through the holes on the motherboard) so I dropped it down a notch, and finally I cut out an opening above the IO to mount the power/USB panel to. I want to use it sitting on a receiver so I'm planning on creating a base which includes legs to allow for airflow to the receiver as well as a sling mount for the original PSU.
edit: Here's the Thingiverse project of the complete case
www.thingiverse.com
mATX Motherboard tray remix by randymarkc
The stand-offs are sized for M3 6x5 knurled inserts. The under MB openings are arbitrarily placed for cooling and M2 clearance. Rev2: -flattened back panel -revised PCI uprights with a stiffening rib for separator panels and made an attempt at snap-out slot covers -added a slot below PCI upright...
Open air case for B75H2-AD motherboard from Acer Veriton (allows for 2 slot video card) by sswilson
Open air computer case incorporating Remix of mATX motherboard tray ( https://www.thingiverse.com/thing:3722450 ) to fit Acer Veriton B75H2-AD motherboard (244 X 200mm). Mainly designed to allow for the use of a 2 slot video card (the original case only has room for a single slot card). Includes...
