Three rads to choose from arrived. I'm leaning towards the furthest left, the the middle one is tempting. The far right is the plainest but it's the only one that has foam in the reservoir to allow some kind of filtering/softening.
In other developments, I've realized I'm going to have to modify one fan. with fans in place there's just no way to tighten the fittings on the 360. They sit too close to the fans (literally too much friction/too tight to seat them). Going to dremel the side of the fan a bit to have a small 'divet' on the fan housing to allow the fittings to tighten, or so I hope. Good thing I have a spare fan :S
If not I'll likely have to use a spacer that's thinner than the compression fitting to allow it to fit.
