Air Cooler for i7-12700K
Nice one you have ! Good for you.
My Rog Strix Z690-E strangely did not want to fire up this morning, i only had it for 5 days. No remedy even using different PSUs. i am not sure if i have confidence with Asus boards anymore. I may get myself a MSi Z690 Carbon tomorrow.
Tech support already certified it as "tossed", i may try to warranty it but only if not too much headache following the annoying processes. Unfortunately return or exchange it is not an option as i modified a bit on the upper part of the VRM heatsink in order to fit with my HDPlex H5 Fanless heatpipe case. That pc was originally intended for my pc-audio setup. So now i am contemplating to head back to re-build a normal pc instead of serving purpose of hi-fi listening
Hi Crazyea,
Between the four coolers popularly compared (
Arctic Freezer 34 Esports Duo,
Scythe FUMA 2, Noctua NH-D15 and be quiet Dark Rock Pro4), only Arctic Freezer mentioned LGA1700 Socket in the product details. And you have Noctua fit well in your system. So can i assume they all include LGA1700 adapter kits in the package now ?
I love the black color one too it looks so sharp.
For both color scheme, so i guesd we must only choose the model NH-D15S (with the "S" after the 15) to have the clearance of RAM Modules ? The NH-D15 has the fans mounted on the sides.
