am4 mounting screw size?
Shadowmeph
I am wondering if anyone knows the actual screw size of the am4 backplate mount I want for my new board and have decided to use my custom water block , unfortunately I need lone screws so that I can use the am4 back plate but i dont have a backplate here so if anyone knows this would be helpful so I dont have to wait until my board gets here then take the backplate and head to Home hardware to find screws , I just want to have everything ready so I just put it all together with out going through to much BS.
I used to just use long screws with out the back plate but I dont want to do this I want to use the actual proper backplate for the board
The screw that mounts the original AM4 retention mechanism to the backplate is a 6-32 SAE 12mm/half-inch long screw.
I think they used to use M4 screws but no longer.
