AMD Fire Pro Issues
Shadowarez
Arctic Canada
heya guys awhile come across an interesting issue with an AMD Fire Pro not sure the card as i have seen it reported as 2 different ones, so i tried a few drivers for windows 7 pro here is the info from log.
Catalyst™ Install Manager
Installation Report
11/07/17 08:18:11
Hardware information
Name AMD Radeon Graphics
Manufacturer Advanced Micro Devices, Inc.
Device ID 0x68a9
Vendor ID 0x1002
Class Code 0x030000
Revision ID 0x00
Subsystem ID 0x3d1e
Subsystem vendor ID 0x13cc
Other hardware
Existing packagesAMD Catalyst Install Manager
HDMI Audio Driver
AMD Drag and Drop Transcoding
AMD FirePro Control Center
Packages for install
AMD Display DriverFinal Status: Fail
Version of Item: 15.201.2401.1009
HDMI Audio DriverFinal Status: Success
Version of Item: 7.12.0.7723
AMD Catalyst Install ManagerFinal Status: Success
Version of Item: 8.0.916.0
Other detected devices
Device ID 0xaa58
Vendor ID 0x1002
Class Code 0x040300
Revision ID 0x00
Subsystem ID 0xaa58
Error messages
Driver Install: the specified driver package was not installed for matching devices
there is zero identifiers on the card itself, so i went with using the serial to try track it down, why doesn't amd make drivers for pro series like the gaming series i need this specific driver or else it won't even install?
MARSTG
Montreal
Are you using FirePro drivers or Catalyst drivers? Do the Catalyst drivers support the FirePro cards?
Shadowarez
Arctic Canada
checked the relive ones dont detect amd hardware, the pro side is like for every individual card. iv searched ti ids its showin as a v5800 FireGL Pro putting in PCI\VEN_1002&DEV_68A9&CC_0300 even gives the same issue as not being able to install the driver. no one has a solotion, i have tried going in safe mode wiping drivers clean/shutdown reboot tried running as admin. making sure im in my admin account wich is the only account to begin with, even tried run as admin from explorer just to make sure, same issue.
Shadowarez
Arctic Canada
found a driver that works but its from 2012. i cant use the new drivers i guess lol, but it works for now i guess thats better then standard vga adapter lol
