AMD Game Build
AurosGamer
Member
Canada
Hello,
Gigabyte X570 Auros Elite Wifi
AMD Ryzen 3600XT Corsair H100i
Corsair 16GB 3600MHz Vengeance RGB Pro
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
XFX RX 5600 XT Thicc II PRO -14GBPS 6GB GDDR6
Samsung 32 Curved Screen FreeSync
Cooler Master MPY-6501-AFAAG-US MWE 650 Gold Full Modular, 80+
Will post bench marks on completion
Bond007
Nova Scotia
Thanks for the post.
Personally I would have gone 3600 (non X or XT), gone to a cheaper motherboard, and put the savings to a higher end graphics card. But there is nothing wrong with your choices and it’s all up to your uses and wants.
Keep us posted!
AurosGamer
Member
Canada
Keep us posted!
I chose the 3600XT to compliment the PCIE 4.0 MB /Corsair PCIe and XFX Graphics Card, thanks for your comments much appreciated
AurosGamer
Member
Canada
INITIAL BUILD SET UP
Entered Bios on start and flashed Bios File F20 to enable AMD 3600XT support for PCIe 4.0 and Memory
New Installation of Windows 10 64 Home
Cooling: Corsair H100i AIO
Bios Setting: Optimized Settings
XMP Profile 1
RX5600XT Pro Bios Installed
CPUZ Bench Reference to my Signature Build
3DMark Time Spy
AurosGamer
Member
Canada
Make sure your games support the monitor
It appears that World of Tanks and CADWWII offer excellent game play on the T5532 with the DP Driver Installed set to 8PCC and Full RBG
World of Tanks set to Ultra HD (70 to 75FPSon signature build) 155 FPS XFX 5600XT set to default
