AMD r5 3600 with Blender 2.81 - The Junk Shop
sherwind2010
Canada, BC
So the 3600 did The Junk Shop in 26mins 16secs at 4.3GHz 1.4v, It did it in 8K resolution.
AMD Ryzen 5 3600 (4.3GHz)
ASUS Prime X470-Pro
Patriot’s Viper RGB Series (PVR416G320C6KW)
sherwind2010
Canada, BC
The Junk Shop in 7mins 9secs at 4.3GHz 1.4v, It did it in 4K resolution.
2mins 23secs in 1080p resolution. So I'll throw the 3700X on there and see what I get.
sherwind2010
Canada, BC
The R7 3700X did The Junk Shop in 5mins 40secs at 4.35GHz 1.35v, It did it in 4K resolution. 20mins 18secs at 8K resolution.
MARSTG
Montreal
would you say the result scales almost linearly with the number of cores ?
sherwind2010
Canada, BC
Not sure about these numbers, 3600 did it in 1,576 secs & the 3700X did it in 1,216 secs. That is 197 secs a core & 262 secs a core for the 3600... something is off, maybe the 3700X does something better. Maybe the 3700X can do the 250x250 tile rendering better than the 3600 that is the only thing i can think of, CPU rendering should do better at a lower tile rendering like 16x16 or 64x64 and GPU from my testing does better at 256x256 tile render.
sherwind2010
Canada, BC
4.3GHz @ 1.375v, Air cooled.
Memory 3600MHz on a x570 motherboard.
The 3600X does 2mins 23secs (best out of 3) with the no settings changed in The Junk Shop. (250x250 tile)
3600X did the 8K (8000x4000) in 23mins 31secs with 32x32 tile rendering.
res 2000x1000, no other settings changed
8x8 tile rendering (CPU) rendered in 2mins 10secs...
16x16 tile rendering (CPU) rendered in 2mins 4secs...
24x24 tile rendering (CPU) rendered in 2mins 3secs...
32x32 tile rendering (CPU) rendered in 2mins 3secs...
40x40 tile rendering (CPU) rendered in 2mins 3secs...
48x48 tile rendering (CPU) rendered in 2mins 4secs...
64x64 tile rendering (CPU) rendered in 2mins 4secs...
