Another mobo dead?
encorp
Sooo over the last week my buddies comp started acting up, then last night it shut down and refuses to boot again; I'm pretty sure it's the mobo; typical symptoms.. it turns on for a split second and then off again. I've taken everything out to make sure I wasn't getting a short from the case... I'm almost certain it's the mobo, the PSU is a brand new Corsair TX750... don't think I really need to list the parts but will if need be, mostly guessing you'll all confirm my hunch.
Safearus
SSM, Ontario
Well, I saw this happen before with a HSF that wasn't completely mounted onto the CPU. Just a thought
Arinoth
Halifax
Fun the "fun" i had with my g/f's "old" mobo that ended up having to get RMA'ed, it sounds like it is the mobo.
encorp
Yep, that's what i think.... anyone know a way I can turn it on and off without using the case? can I jump the pws?
Arinoth
Halifax
What Saf said, you can short or jumper the power pins together with the psu connected to nothing other then a case fan to see if the psu does this problem on its own
encorp
Yep; I jumped it, and it does the same exact thing. Damnit, just built this thing two weeks ago... haha crap! Anyone got a spare S775 mobo I can borrow?
