Antec 900?
richuwo11
Kitchener
i am looking into getting a new system and have done a fair bit of research although i wanted some opinions on the Antec 900 case for my system...
  • intel c2d q6600
  • evga 680i a1
  • evga 8800 gtx
  • ocz reaper 8500 2gb
  • ocz gamexstream 700 watt
  • zalman 9700 cpu fan
  • auzentech x-fi prelude
does anyone think the 900 would have sufficient airflow? or should i go to something like the thermaltake armour?
enaberif
Calgahree, AB
  • intel c2d q6600
  • evga 680i a1
  • evga 8800 gtx
Worst case ever! Go for the p182 as its much bigger and better.
richuwo11
Kitchener
well why is it bad? most of the reviews seemed ok for it...and you would recommend the p182 over the thermaltake armour?
enaberif
Calgahree, AB
I'd recommend the p182 over anything :D
Antec 900 has a poor power supply mount and front panel connector wires are to short.
born2expire
Member
t. bay, on
i second the 900 not being good, i built another one of them this morning (done about 10 of them now) and not only is it ugly as sin but the cable management is awful. fine they put ties inside, big deal there is not one place to run the cabling to backside of the case unless you cut it yourself. the one thing i can say about the case is that is does run cool.
id say look to p182 (amazing case) or anything by silverstone (if you have the bucks).
JD
Toronto, ON
Wow so negative...
I own one and it has served me well. All you guys must be used to huge cases or something. I, on the other hand, am used to small tight cases. It's worked out fine for me, for the most part...
My 4pin 12V ATX plug (CPU power) was too short to reach nicely (without going over the motherboard), so I had to pickup an extension for it. The front panel connectors are a bit short, but they just fit for me. Tighter than I'd like but it works.
Seeing as you are going for the GameXStream PSU, you'll have the same issue I did. Might want to look for something with longer cables.
I like the way it looks and it does have quite good cooling. There are various mods you can do to it as well if you have a Dremel or such. You can cut various holes around the motherboard to route your cables in behind. I haven't done any such mods to mine.
It's just something you either love or hate. Nothing is perfect.
Heres some pictures I have lying around:
http://i85.photobucket.com/albums/k71/jdrom17/my computer/DSC01650.jpg
Cleaned up bottom. Drilled 2 holes to wrap a zip-tie around to hold the PSU cables against the back. Cables in-front go to hard drives, video card and any extras sit in the front there. I've been meaning to move them to the back as well though.
http://i85.photobucket.com/albums/k71/jdrom17/my computer/lcs/DSC01655.jpg
Overall shot
http://i85.photobucket.com/albums/k71/jdrom17/my computer/lcs/DSC01654.jpg
I've replaced the rounded IDE with a flat-ribbon cable as well, so it looks a bit different than the pictures. Too lazy to take/upload pictures though.
richuwo11
Kitchener
thx for all of the opinions... i still havent decided on which one im gonna get yet...
the p182 also has a bottom-mounted PSU so i am assuming that if a gamexstream in a 900 doesnt have a long enough 4pin plug for the motherboard the same will happen with the p182?
Unklmo
Mtl, Qc
i had no problems with the psu mounting in mine, and the only cable that was too short to reach was the HD-Audio/AC97 cable. a cable extension from Performance PC's remedied that quick.
exactly what i did, running most of my cables through the bottom in the last drive day and back in through to the front in cut-outs i made close to the connections.
i will admit though, after installing the 8800gts and then throwing on my cpu chilling system it certainly does not leave you much room. when i first picked the 900 i thought there'd be plenty of room, however after putting it all in there,... let's just say it's a lil snug.
enaberif
Calgahree, AB
People shouldn't have to mod their cases to make it work and a lot of power supply you put into the 900 mount upside down and the fan faces the wrong way.
