Antec Flux Pro Noctua Edition Review
moocow
Vancouver, BC
GN got their hands on the production version. TL;DR, very little performance difference compare to the original, at least when GN tested it. In their opinion, not worth 2.5X the price of the original ($160US vs $400US) at time of publishing. But if you buy the original and fill it with Noctua fans, it would be $460US. In their opinion, unless you like the color scheme, no point in buying this.
I honestly don't understand how anyone could think that case deserve's that much of a price hike just becuase it has noctua Fan's.
I love Noctua's NH-15D aircooler because it plain and simply does the job without making to much noise unlike others I have tried in the past,and I do really like Noctua's fan's for how well they perform but they have gotten pretty pricey.
With Noctua's fan's I think they are still really good but the Phantek fan's if you ask me do the really well for case fan's.
where do ppl buy the T30's i cant seem to find em cept ebay and i dont think they are worth $200+ shipping for 3 fans.
I haven't seen them in a while myself and the last time I needed fan's for a build I did I went with the Arctic fan's as I have had good luck with them as well.
but what about the quiet? I NEEDS the quiet with the airflows!
I'm using 3 Arctic 140mm fan's in my Phantek Enthoo and I don't find them loud at all and they are just your standard 3 wire plug's.
I also find that 120mm fan's are normally louder then 140mm fna's because the 120mm has to turn faster to more the same amount of air,I always try and use 140mm fan's whenever possible just for that reason.
I know that my Phanteks 200mm front fan barely makes any noise and I think it is rated at 850rpm and man does it move a good bit of air,I can often feel the air around my feet moving when I have the fan's turned up full blast.
Check these fan's out they claim to be phantek fan's and I know I gt a replacement 200mm front fan for my Enthoo Pro and it looks and run's exactly the same as the stock fan,same rpm and airflow from I can tell,I wondering if the seller is also making phantek fan's and moving some out the backdoor or if the phanteks T30 never was their design and they just buy it with their name slapped on it.
You can get 3 for 137 off aliexpress.
https://www.aliexpress.com/item/100...|x_object_id:1005006003317946|_p_origin_prod:
