AORUS FV43U 43" 144Hz 2160p
Th
The screen is actually around 25lb, not 10! (I think they put KG in their specs). I have the same screen. I am using an amazon 100x100 to 200x200 adapter, and the Ergotron LX Wall Mount. The LX is only rated to 20lbs max, so I really had to max out the tension screws, but it works! My Mega Desk is complete with 2 x 22in 1080p Dell screens to the left.
I think the half eaten bag of Doritos is a nice touch :)
due to the weight I would serious consider an articulating wall mount...perhaps one that is height adjustable. a solid brand with decent pricing is Amer mounts...though when you start getting into the higher weight brackets the price starts to scale steeply.
edit - for stand / edge or grommet clamping monitor stands. at 43" you're pretty much TV sizing so the desk based mounts will be quite limited. if your setup is unlikely to change any time soon, then going with a fixed wall mount makes the most sense. :)
