(Appears Solved) PC starting by itself.
upcoast604
Sunshine coast, BC
The x4 965BE pc has started turning on by itself after I've shut it down.
This started after Teksavvy cable was down for the day in BC this past Saturday 11th.
Win 10 64bit, any ideas?
Ps, I've already turned wake on lan off in bios about a year ago when I first got the motherboard.
Edit, it seams that for whatever reason magic packet and pattern disabled stopped whatever signal from the network from turning the PC on anymore, so it's basically fixed.
upcoast604
Sunshine coast, BC
I just tried disabling magic packets and pattern match, see what happens tonight.
Shut Down Wake Up is enabled would it be bad to disable it?
I think if the switch was bad it would be firing up asap not 20-30 min later, I'll have to start timing it because it's just too coincidental with the whole teksavvy ordeal this week end.
ZZLEE
KANATA
Switch on power supply til its sorted.
Sounds suspishes of a hack.
Edit: Look up "Glasswire" real interesting software.
