are there any wall-hanging Qi chargers?
Are you using an iPhone? MagSafe would hold a phone on a wall easy, if you attached a MagSafe charger to the wall. I'm not sure if other phones do the magnet thing. It's pretty slick I have to admit. Your phone just snapping into place to charge is very convenient.
Something like this for example (egads... would people actually drill into the dash of their car?! *shudder*):
I mean, it depends what you're looking for exactly. You could buy an in-wall/recessed charger that you could insert inside a wall then build any shelving or stand you wanted to work with it. Or you could put up a cheap shelf and just sit any charging stand on it.
There are several options for magnetic case/wall mount combos that allow attachment to the wall. Such as this:
Or car chargers you could likely convert for wall mounting:
I'm sure there's a ton of other options too depending on how creative you want to get, what you're envisioning and what your budget is.
@Lysrin I have a Pixel 9 Pro XL...so I don't think MagSafe will work.
@Caldezar that first Moshi looks perfect, but daaamn on that price. I'm thinking I might have to get myself a simple $20 pad charger and jury-rig it onto a lil shelf with a lip to hold everything in place. I think PrimeCables has a couple on liquidation, if I can deal with them being 'white.' LoL
