i have an asus hero alpha and i bought some cheapish rgb strips from ebay. both seem to work fine until i enable the music effect. one strip basically strobes blue and the other one is mostly green and neither seem to cycle through the colours as i expected them to. it just seems they dont match the signal well enough for my liking. i can take a video if im not explaining it well enough.
both are plugged in properly and like i said every other effect functions the way it should so basically i just want to know if this is normal or do i need to try some different strips. Im running through hdmi to my yamaha rx-v671 receiver just fyi, dont know if that makes a difference or not.
any info is appreciated, thanks.
