Asus P8Z68-V LE & i7 2700k - no Display (iGPU)
Hey everyone, just running into a bit of trouble here with a new build.
Basically what is happening is that I cannot get the iGPU to enable. Once I make the correct setting adjustments in the BIOS and reboot, I get a blank screen. And then after about 45 seconds, the unit reboots. This was symptom from the initial boot (1 stick of ram, stock cooler, no headers attached etc.)
But here is the kicker, a dedicated PCIE GFX card works fine (old 8500GT). While the system is running on PCIE it runs like a champ, passed all memtests and cpu tests.
The only thing I have NOT tried to do is swap the PS, which would be odd, because the unit has run for +20 hrs on it using the PCIE card
My gut is telling me bad mobo, although I don't want to admit that since I am not too fond of RMA process through Direct Canada, since there appears to be no post-sale support from this company.
Any tips or suggestions ?
Thanks in advance
TbF
Mobo: Asus P8Z68-V LE
CPU: i7 2700k
RAM: Corsair Vengence 4x4
Arinoth
Halifax
Have you tried connecting to a different video output on the back. Aka rather then using vga try DVI. Perhaps one of the output connectors or chips driving it is defective.
Do you live in the GTA? If so you could drive or mail your item to asus for the rma (as they luckily have an RMA facility in the GTA which you can even drop off the item to be repaired once approved for RMA).
Thanks for the quick reply Arinoth. The mobo has been in my possession less than 24 hours, and no I live about 3-4 hours southwest of the GTA.
Yes I have tried all onboard ports, after resetting CMOS and pulling battery. With and without the PCIE card in place.
VGA - nothing
DVI - nothing
HDMI - nothing.
As a side note, obviously the Intel HD 3000 is not detected in Windows, since the BIOS is failing when it tries to enable it.
dandelioneater
Kelowna, BC
Have you tried clearing cmos? The board may be looking for graphics on the pcie instead of the igpu. Similair sort of thing happened to me once on a 775 board.
Just wanted to post a follow-up
Replaced mobo (and upgraded :)) with Asus P8Z68-V Pro/Gen3 and all is working well. So the proc is ok, and my gut was correct again.
Thanks for all the help guys
TbF
