asusp7p55D-E pro memory detection
car-man666
Member
my asus p7p55D-E pro in the bios reconnyses only 2 mg of ram on my kingston hyperx khx1600c9d3k2/4gx, win 7 see the missing ram but say it can't be used, how do you fix that,please kinda frustating
_dangtx_
mtl
one at a time, load bios defaults,save and reboot. pop the other one in. shut down , power up. see what gives.
SugarJ
Langley, BC
If you have swapped the memory around and it still gives the same problem, it's probably a defective memory slot. dangtx is suggesting you boot one stick at a time to make sure the memory itself isn't defective.
_dangtx_
mtl
that or mobo being picky with that particular set. i have a giga board that doesnt see all the sticks presently in use there unless i go one by one. dont ask, dont tell=it works. :)
_dangtx_
mtl
cool. let us know how it turns out. drop by the folding forums, as well, if you like :)
car-man666
Member
well finely, i got the time to try one at atime and now win7 recon my 4 gb of ram, thanks DANGTX picky my mombo but i does the job.... problem solved
