Audigy 2ZS External IO box question
jcmaz
Vancouver, BC
Hey guys,
I'm using the Audigy 2 ZS Platinum with the External IO box right now. 5.1 surround sound is awesome with this unit using the DanielK drivers. However, the IO box will not work :(
So how do I get the IO box to work? Does it need more power than the sound card can provide, hence the point of a "power connector" on the sound card?
Where can I get that specific cable?
Thanks!
jcmaz
Vancouver, BC
Update: so according to a user on Overclock.net, I have to plug in a 4pin floppy power cable. I'll try that tomorrow and we'll see what happens...
Dr_BenD_over
Fallen Folder
Nova Scotia
Thanks!
Are you referring to the cable that plugs in here.
I think I still have one... It may be Dell specific though...
jcmaz
Vancouver, BC
Alrighty, I've plugged in the floppy power cable. VOILA!!! The IO box works like a charm :)
Thank you to those that pitched in and helped!
