audio/video stutter issues
lowfat
Grande Prairie, AB
https://www.thesycon.de/eng/latency_check.shtml
Easiest way to find what device / driver / software is causing the issue. Doesn't work well w/ Win 8 tho.
Unplug all devices, close all software. If you are getting spikes its probably a driver or hardware issue. Uninstall drivers until it stops. If you don't have spikes, plug in usb devices one by one. If still nothing then try software.
Shadowmeph
that is what I do after asking for suggestions and trying it out on a different pc or laptop
Mr. Friendly
British Columbia
well, being there were no changes to the system and this started, I wanted to see if anyone had any thoughts as to what might be going on. it's likely some sort of driver conflict, but what? when internet cache is cleared up, the problem disappears.
JD
Toronto, ON
so annoying. I think I will just do a reinstallation of Windows.
Usually the easiest, just recently I was confused as to why my X520-DA2 NIC wouldn't link up with the 10G SFP modules as the switch said the link was up but Windows wouldn't show it. Reinstalled Windows and everything just worked :doh:
Mr. Friendly
British Columbia
so it's Webroot. no clue what the issue is as I can't find any fixes online...only one thread on their support community that said updates had fixed this issue previously.
sent in a support ticket. let's see what happens!
Sagath
Folding Team
Edmonton, AB
I hate to say I told you so, but I did.
Edit: wait. Is webroot an addon or stand alone software?
