Battlefield 3
Prolab
Brampton
I've had my fps be really bad and really good. I've read restarting your PC can do wonders for this game. If that doesn't work try changing a few settings and then rebooting again. It is buggy, that's for sure.
Thats what i did. As soon as i D/L the beta, installed it then tried to play it - it keeps giving me a connection error.
Closed everything down, restarted and i havent had any problems since (except when the server is full).
either you have the settings too high, or this game loves crossfire
Photo Albums - Imgur
My results
So far, with my resolution (1920 x 1080, X-Fire enabled):
- Ultra - avg around 45 - 50 fps according to fraps
- High - avg around 65-70 fps according to fraps
Keywork
Niagara
I've put in a few hours today and i'm quite impressed! The two different starting gun sets kind of messed with me but all is well. Took a while to tweak controls but I was up and pwning noobs in no time.
Also, with my lone GTX 460, i'm able to play on HIGH at 1680x1050 without a single hiccup. I didn't get a chance to monitor actual FPS but it was butter smooth with no issues.
DenisS
Toronto (North York)
So, you tried the demo and liked it, but you did not yet pre-order the game? Well, you are in luck :biggrin:.
One lucky person will get 25% off at origin by using the code at the checkout.
7a2tt97474b66aa
DenisS
i use msi afterburner for fps and vga temps, i have a custom fan profile as well. in bf3 if you press ctrl shift s (not sure) it will show fps, but only while those buttons are pressed
Prolab
Brampton
Pffftt.... now im having the same problems as Arinoth.
No matter what i do, it'll never go full screen. And if the chance it'll happen, i do click it and then the screen closes.
SOB!!
