Anybody out there currently have one of these set up with most of the router functions disabled for use with a secondary router/controller/firewall? If so, what are your settings, and anything I should be looking out for?
I'm going to do my own research on this, but in the past the available info was all over the place with some postings suggesting that it can be made to work, but others stating that it's flaky at best, and purty near impossible at worst so I'm wondering if anybody here has a current config that's working who can point me in the right direction.
Not looking for anything too fancy... my intention is to leave the IPTV connections (both wireless and wired) to the home hub 3000 (don't want to be bothered with the VLAN setup(s), but hopefully get my internal home network running off of a ubiquiti USG (and cloud key) along with a couple of ubiquiti APs (one at either end of the house).
So far, it looks like I can get away with setting advanced DMZ which will allow the USG to use the external WAN and bypass the router's firewall. If that works then great.... but what about DHCP? I'm still going to be connecting 1 wired port + multiple wireless STBs for the IPTV.... so I'm not sure I can just disable DHCP on the router. Would avoiding DHCP conflicts be as simple as assigning a different IP range to the USG?
Thanks in advance for any suggestions.... probabaly not going to have the hardware in hand for a couple of weeks but I'd like to get a game plan in place for when it does show up.
