Best and most affordable liquid cooler for Ryzen 9
Mindfield
Member
Brampton, ON, Canada
Hi guys,
So I recently upgraded from a Ryzen 7 3700x to a Ryzen 9 5950x and bought a Noctua NH-D9L thinking it would be an adequate cooler (according to Noctua’s website it’s on the edge of acceptable performance but no headroom for overclocking, which I don’t care about). It isn’t. Not even close. Idle at 65°C, tops 80°C under load and throttles down to 3.4Ghz.
Clearly liquid cooling is in order here. I had experience with liquid cooling on my old FX
9590, but that was a 220W processor with a 75° max (realistically 65°). I ran a Corsair H100i and Coolermaster ML240L and they did fine.
However, This new CPU runs hotter, so I don’t know if a 240mm liquid cooler will cut it. Any suggestions? Is 240mm enough or should I go with a 280 or 360? Would a Coolermaster ML240L or ML360L suffice or would
I benefit more from a better brand like Corsair? Preferably something under $200.
Sagath
Folding Team
Edmonton, AB
The difference between LC AIO brands almost boils down to fans and rad. There is only 2 or 3 actual types of AIO out there and most companies just slap their branding on it and throw it in a box.
That being said, from the research I've done I agree with the lads above, you're not going to find a better bang/buck than the Arctic Cooling models.
Also, if you're comfortable with it I would look into reducing your offset voltage in the cores. It can save you a lot of heat and actually increase clock speeds modestly when done right.
FreeKnight
Edmonton, AB
As Sagath mentioned, there's only a couple manufacturers (due to patent issues) so most are just a different look on the pump/block combo and the supplier's chosen fans.
I'll give a nod out to the lian li galahad coolers for one perk though; they have a fill port on the rad. How likely the unit will run long enough that you have any substantial coolant loss vs the pump just dying is a separate topic, but if you think you'll have that AIO for years and it'll never die, that's a potential nod in their favour that others don't seem to have.
