Best place to get a replacement power cord for a Toshiba laptop
Dwayne
Courtenay, BC
Looking for a brick replacement. The old cord broke at the laptop input end, and while I did a quick solder job it is not going to last. Any suggestions where to get a decent replacement for part number PA3714E-1AC3?
Thanks!
Mr. Friendly
British Columbia
you'll have to get a universal AC adapter most likely. one that comes with multiple heads...so go to BB, Staples or London Drugs and see what they've got.
sswilson
Moncton NB
I've ordered parts from battdepot in the past and they seemed fine. If you don't mind cheap but model specific they've got a replacement under $14.
AFAIK, Dell's the only laptop manufacturer that still mucks up using a universal charger.
Dwayne
Courtenay, BC
Thanks for the replies. I did a quick search and there seems to be "not much" out there. I'll try Battdepot. I am pretty sure I have ordered from them before too, and it is under $20 so it is worth a shot!
Dwayne
Courtenay, BC
Dwayne
Courtenay, BC
Looks like the Battdepot part was just fine, shipping was more than the part though, but it works.
