Best SSD for Boot Drive?
Charmster
Hello,
I am thinking of installing a boot drive and want enough space to store Windows7, MacOSX, and Linux and some leeway to store other programs (~10GB worth, maybe more).
Any suggestions will be appreciated.
Thank you for your time.
NyteOwl
Nova Scotia
I'd guess you're looking at a 120GB if you want some breathing room on the drive. My preferred brands are Intel and Crucial - others have their favorites.
bigbui
Active member
Ontario Mississauga
you definitely need around 120gb ... maybe 90 is fine ? -- don't take chances becuase you might need more space later on.
i also prefer intel, however im using OCZ vertex 3 120gb and i love it =D
yamawho
Rosemere, Qc, Canada
I'm using Intel 520 60GB.
I installed win 7 64bit with SP1 with updates and turned off hibernation ... 18.54 GB used :punk:
60GB is enough.
stoanee
Lacombe Alberta
60GB is enough.
Nice, I just bought a 520/120gb and am installing 7 on it. I am not sure how much space I will end up with yet but I found it odd that the system reserved 9 gb.
Insomnia9669
Mississauga, ON
