Best SSD for gaming on PC ??
Chess Gator
Hi fellows,
What is the best SSD for gaming on a PC ?? The online reviews are all over the place!
Thank you,
CG
That depends on your budget really. Samsung usually got pretty good speed but I'm not touching them for RMA support reasons. I'm running a SN550 1TB as my Steam drive, it's decent but I don't really notice the speed increase. In my uneducated opinion, I would look for something with fast read since games are pretty much read only after you installed them.
I run a bunch of Adata but you have to be careful cause they like to change out parts on their SSD and not tell you, but really any decent nvme drive will be just fine with the speeds they have, imho
WD Black SN770 review is a bit all over the place. It's DRAM less and Storagereview basically complain it's no different from a Blue SN750.
