BF2142 v1.10 Patch Release Tomorrow
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
It's been noted by EA that the official Battlefield 2142 v1.10 patch will in fact be released tomorrow, December 19. Until the patch is released and the mirrors pour in, here's the change log to tie you all over:
BUG FIXES
- Remove ability to resupply all unlimited ammo objects
- No longer able to use Sentry Gun pushing player into Titan Crate collision
- No longer able to use RDX DemoPaks drop through first section of the 3rd and 4th upper hallways of both Titans
- Away Bonus is now used when calculating in-game promotions
- Improved communication with GameSpy Database
- EU Duty Ribbon/PAC Duty Ribbon awarded correctly when all criteria are fulfilled
- “Commander score" statistic no longer resets to zero
- Enabled tabbing to password field when using a dedicated server
- News Tickers Speed time to display increased
- When scrolling through the list in Multiplayer you no longer move both at the same time as the server info
- EMP effect on Gunships reduced from 4 to 3 seconds allows the gunship to recover when throttled up at medium altitude
- SL drone: Tweaked the acceleration on the left right aiming for the bot. It now acquires targets properly
- Adjusted pistols: Increased ROF Clamp values, slightly reduced damage fall off over range
- Adjusted up the damage of the HMG rounds to counter its lower RPM
- Adjusted and/or increased entry radius points for all vehicles
- Removed unused RangeFinder setting from EU Walker, Titan Guns to fix the APC/Railgun/FAV draw out bug
- Fix for latency and TV guided missiles (lowered the acceleration on the missile and fixed firing lag)
- Fixed active camouflage to no longer offset image
- Changed default server port to 17567
- Update to most current PunkBuster client files
FEATURES
- Reserved Slot Enhancement (Gives reserved slots the ability to be filled if not used)
- Unranked Unlock Control (Option to give all first level unlocks and Enable/Disable control of all other unlock levels use)
- Spectator Function
More Info Here
