In the past, it was more common for workstations to position themselves among computers on the PC market.
Their built-in graphics card could significantly enhance the level of work efficiency for 3D CAD or video editors.
Combining these two working environments’ demands,
nearly three years later companies started to produce their workstations as a brand product line.
After all, all workstations position themselves as high-end products with the specifications required by the professional users who prepare a certain budget for this kind of product.
I’d like to share an overview of MSI WS72 6QJ. As you can see on the box,
the logo is different from the Gaming Dragon logo as its light green and “workstation” highlights the product positioning.
The large backpack also has the same logo.
WS workstation series and the company’s GS series share a high degree of similarity in appearance.
They both belong to the slim design product series. Even though the screen size ranges from 15.6” to 17.3”, small weight and thickness still deliver extraordinary performance.
The dimensions are 418.5mm x 287mm x 19.9mm, the weight is found to be about 2,630 gram.
It’s lighter than GS72 (2.6 kg) and its thickness is below the one Intel 15-inch Ultrabook’s specifications state (21 mm).
WS72 is a great combination of both an Ultrabook’s slim design and high-performance hardware.
The backside of the backpack is made of very solid materials. The separator inside is also quite thick. In terms of overall creativity,
some individuals may think that there’s still space for improvement and that GS70 looks better.
Improved texture and fashionable design would let people like it more.
WS72 6QJ Included accessories:
CD drivers, Quick Start Guide, Product Features Guide, Two years warranty, DELTA 150W power adapter, power cable, Mini DisplayPort adapter, MSI dedicated mouse.
A-side is covered with black brushed metal with a car hood design.
Probably due to the materials change, WS72’s metal touch is obviously better than GS70’s.
The main design of GS72 from Gaming Series is the same as WS72; the new generation of materials and design are now being introduced.
When the laptop is on and in use, the logo illuminates light green enhancing appearance of the texture.
B-side is a 17.3-inch screen which is UHD 4K with a resolution of 3840x2160.
It features a wide view IPS panel and supports 100% Adobe RGB color gamut which enhances the color accuracy.
WebCam with fixed focus lens is FHD 1920X1080p and is capable of recording video at 30fps.
The frame is made of matte plastic material. The thickness is within the common scope and seems to be thinner than WS60.
As for the internal mechanism these high-end hardware designs are necessary,
C and D parts need to have a certain volume to in order to achieve high performance.
As a concept of big length and width in the machine,
if the length X width dimensions let the frame area be narrowed then it will definitely improve the thickness.
WS72 can be this thin and there are no other competitive models which have the same length x width dimensions but are larger in weight.
It’s therefore already considered to be a good level product.
Most of the C-side is also covered with black brushed metal and is similar to A-side.
The actual surface area and the body thickness are similar to Dell Alienware 17.
The notebook is equipped with thin full-color Steelseries keyboard which is common for MSI high-end notebooks. The default color is blue.
Using the software, users can choose the backlight color they want as well as display color mode.
Individuals used to think that Steelseries had soft keys, however this time WS72 has improved the force feedback.
In terms of high-end notebook market, WS72 has improved the feeling of typing on a keyboard quite a lot.
The power button is in the top center and is illuminated with white during notebook’s use.
It’s illuminated with orange or blue when dedicated or integrated graphics card is in use, respectively.
The speakers are still by Dynaudio consisting of 2 channel- and 4 usual speakers.
Four single speakers are located in the chassis area which is a more special location for the sound to come out.
The following paragraph includes detailed comments regarding the sound.
The grid above the keyboard is used for cooling, not for the audio.
On the bottom left of the C-side there are 7 status indicators.
The left are right buttons feel like scissors design.
It will take some time to get used to the strength control.
Line out \ Line in \ Headphone-out
On the left side, from left to right: GPU cooling grid\ RJ45 Gigabit Ethernet \ HDMI \ Mini-DisplayPort X2 \ USB 3.1 X2 \ Line out \ Line in \ Headphone-out
