Bios/mem/SLI?
frosty
Windsor, Ontario, Canada
theres an option in the BIOS about SLI memory performance... Does anyone know about this?? I looked inside the setting and there are a bunch of percentages to use..... leave it alone or should it be set to something specific.
thanks..
3oh6
Edmonton, AB
Website
jodybailey.ca
it refers to SLI compatible memory. the term SLI is just NVIDIA marketing garbage but it refers to EPP enabled memory, Enhanced Performance Profiles.
you can basically automatically overclock memory that is SLI/EPP compatible. i personally don't like it because overclocking manually is the way to go but there are some benefits for those not fit to clock their memory. HTH
