Completed Bitfenix Prodigy Watercooled
Father Fuzzy
B.C.
Tubing Madness
After a couple tries at the tubing decided no quick disconnects
will be barbs with black zapstraps
Loop order is rez-pump-240rad-cpu-120rad-Gpu-rez
Drain installed with Bitspower valve plus end cap
Bitspower tee to rez
trying to clean up some of the wiring
Nice warning
Graphics hookup
Time to leaktest and sleeve a few cables
Mnpctech
Minnesota
Good to hear, next time you order, give me heads up, I'll toss in a sample of something.
and Keep these awesome updates rollin in :thumb:
Prolab
Brampton
Where did you get those QDC for the CPU block?
Ive been looking for awhile to get those.
Father Fuzzy
B.C.
I will :thumb: for sure
Did you have to do any modification to the water block's backplate to fit on that board?
I was about to cut it then I used extra washers to get off that chip/block thang
and was extra carefull about that turning into xtra pressure on the chip
I got them at ncix and a few from dazmode I have a ton of them in my 44 Magnum rig
so I can swap out motherboard tray which I hope to try soon
It was just too tight in the prodigy with the qdc's and 3/4 Tubing and fittings onhand also fiqured I wouldn't be swapping it out much only itx board I have
A 200 mm rad would fit nice in this Case and keep the 5.25 drivebay
bundymania
Germany
Very nice case & worklog you have there ! The modding stuff from Bill looks awesome, maybe he wants to equip one of my next builds with some items :) ! I plan to get the black prodigy version, when it´s available here in germany. Some questions regarding to the rad configuaration: Is it possible to install a 240 rad in the front AND in the top, both with 25mm fans ? Or a 200mm rad in the front and another 240 in the top ?
Thanks and keep on modding :)
