Black/yellow plugs ripped off 3090FE send help
Shadowarez
Folding Team
Arctic Canada
I'll get a pic once I get a chance I got the ribbons out no issue when trying to get this one out filling a YouTube vid the whole plug came off I can solder it back I got the tools and know how but how effed am I is that the 2nd fan or just the LEDs as I see that's where it's leading to in the shroud?
Sagath
Folding Team
Edmonton, AB
Hard to tell from the image, but it looks like they're crimp on push-pin connectors. Something similar to these;
You may be able to remove them from the plastic connector somehow (pushing/prying a plastic tab?) and gently open them up to recrimp them on the wires.
Edit: Wait, you removed the entire connector off the PCB, not the wires from the pins?
Uh. Yeah, I'll need a pic to see what we're looking at...
Shadowarez
Folding Team
Arctic Canada
According to the GN video the lighting cable Phew will post pics soon as this is done now to remember which screws went where 😱
Shadowarez
Folding Team
Arctic Canada
Ok temps are amazing except I have to have vsync on otherwise I get the fan ramping up to 4000 rpm for like 3-5 seconds then it dies down and go back to 40000 rpm in Destiny 2 but oddly enough The Last of Us part 1 cranked zero issues with vsync on in that.
Bond007
Nova Scotia
You should not be hitting 100% fan speed just by running a game without vsync...that would indicate an issue to me.
Or am I misreading your post.
Shadowarez
Folding Team
Arctic Canada
There is most definitely a issue I'm seeing with it on or off same thing I that game I'll try another see if that's the root cause. But GPU log is showing 104c on memory randomly what's odd doesn't happen in Last Of Us at all at any point.
Shadowarez
Folding Team
Arctic Canada
Wondering if these pads are garbage or zif I didn't put enough thermal paste on the die.
I shoulda took a before pic the thermal paste on this was like chalk and die was exposed. This kit didn't have any pads for the back so I added the grey ones thermal right I think 0.5mm I'll take it apart again see if there is any not making contact.
spent $140 on tim pads 0.5x2 packs 1mm 2mm 2.5mm just to make sure I got enough and right sizes. Even used my digital Caliper to measure the junk that came off.
Bond007
Nova Scotia
As long as the new ones are the right thickness, I think that looks pretty good. On the back, do you have one section with 2 pieces stacked? If so I wouldn't double up just a corner, as the change in thickness may affect contact on nearby parts. Fingers crossed it works out fine for you!
Shadowarez
Folding Team
Arctic Canada
it is but its very very very thin the pad ripped in a odd angle so added that bit it doesnt overlap much if at all i didnt want those parts bare. ill tinker once im off again see if its just a thickness issue ill know for sure once i take it apart and check pads.
