bluray program stopped working
kyle_L
Port Coquitlam, bc
i just upgraded to a gtx 460 and now when i try to play a bluray the program tells me it can no longer output sound via my spdif cable. any thoughts on this in using power dvd 9
KaptCrunch
Ontario
check patch for your version of player current is build 2528
click tools icon of player(hammer and screw driver) then audio tab, change output in speaker enviorment
note: whats set-up in windows sound, what sound chip/card are using? may have to adjust in thier control panel
mine don't show in information, but can hear sound when S/pdif in speaker box. for in windows thats what is set-up in sound properties
other is check firmware of video player optical drive
here's what shows on mine
Player information:
Player region code: 1
Current drive: D:
Title region code: 1, 2, 3, 4, 5, 6, All
Audio attributes: Not available
Hardware Information:
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ running at 2724 MHz
3DNow! technology: In Use
Enhanced 3DNow! technology: In Use
3DNow! professional technology: In Use
IA MMX technology: In Use
IA sStreaming SIMD extensions: In Use
IA SSE 2: In Use
Video accelerator: DirectX VA (not in use)
Multispeaker audio device: SPDIF Out (Creative SB X-Fi) (not in use)
S/PDIF output device: SPDIF Out (Creative SB X-Fi) (not in use)
Hardware support:
DXVA1 Mpeg2 Support Profile: BSP:(X) IDCT:(O) MC:(X) (via VMR)
DXVA1 H.264 Support Profile: BSP: (X) BSP_Intel: (X) MC: (X) MC_ATI: (X) MC_NV: (X)
DXVA1 VC-1 Support Profile: BSP: (X) BSP_Intel: (X) IDCT: (O) MC: (X)
DXVA2 Mpeg2 Support Profile: BSP: (X) IDCT: (O) MC: (X)
DXVA2 H.264 Support Profile: BSP: (O) BSP_Intel: (X) MC: (X) MC_ATI: (X)
DXVA2 VC-1 Support Profile: BSP: (X) BSP_Intel: (X) IDCT: (O) MC: (X)
