Boot error, need help.
BootlegUsher
Last night I turned on my computer and was greeted to this message (see attachment).
I didn't make any hardware or software changes. The only thing I can think of is I installed Windows on a new SSD a number of months ago but it didn't work right so I RMA'ed it and went back to using the old drive.
I have a full retail version of Windows 7 Home Premium 64 bit.
Any advice on how to fix this? I tried putting the boot CD I'm and clicked the repair option but it didn't do anything.
Any help is appreciated!
ZZLEE
KANATA
Cant see attachment but run though your drivers Windows has been playing fast and loose with driver updates recently.
BootlegUsher
Sorry it took me like 10 minutes to figure out how to attach the photo using a phone instead of my computer. Could you please elaborate on how to run through my drivers? Do I do that using the boot CD?
clshades
Calgary
You should be able to choose your boot device via bios or throught the load menu. If you have a really old mobo the option wont be there.
KaptCrunch
Ontario
The system found unauthorized change on the firmware, operating system or UEFI drivers
Press[N] to run the next boot device,or enter directly to BIOS Setup if there are no other boot device installed.
Go to BIOS Setup > Adance > Boot and change the current boot device into other secured boot device
sounds the boot drive not there or unformatted or another OS then one trying to install
what OS trying to install w10? if get all your motherboard drivers on a usb stick and win 10 iso installer
(read "Perform a clean installation using a USB or DVD")
and a formatted drive to install
follow screen
KaptCrunch
Ontario
possible but something changed MBR for bios to halt boot
IMHO stick with win 7 for third party stuff may work or not
SugarJ
Langley, BC
Looks like it may be an issue with UEFI Secure Boot. It's possible you picked up a virus.
