Gooday
Member
Boots twice? (P55 LE) Faulty CPU/motherboard
I just build a new computer and when I turn it on all the fans go very fast and then it shutdowns after 20 seconds then turns back on after 2 seconds. During that time the display is black. After it turns back on, the BIOS screen shows and I hear the "1-1-2 Faulty CPU/motherboard." beeps.
Thanks
Specs:
Intel Core i5 750
EVGA P55 LE ATX LGA1156 DDR3 CrossFire 2PCI-E16 1PCI-E1 3PCI Sound GBLAN Motherboard
G.SKILL F3-12800CL8D-4GBRM Ripjaws PC3-12800 4GB 2X2GB DDR3-1600 CL8-8-8-24 Core I5 Memory Kit
Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM
OCZ ModXStream Pro 700W ATX 20/24PIN SLI Ready Modular Cables 135mm Fan 80PLUS Power Supply
Coolermaster Storm Scout Black ATX Tower Case 5X5.25 5X3.5INT 120MM & 140MM Red LED Fan No PSU
Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM
Acer X233H 23IN LCD Widescreen Monitor Black 1920X1080 40000:1 5ms VGA DVI HDMI
nvidia 9800GX2 (temporary until I get my 5850)
Thanks
Specs:
Intel Core i5 750
