D
da_bradler
Guest
get a gtx460 768mb for like ten dollars more, there are plenty available at 120-140$ don't get a 6850
Building a gaming rig doesn't have to cost you an arm and a leg. In this article I'm going to give you a list of current parts for under $600 before tax...
Processor - AMD Athlon II X3 3.2GHz Tri Core - $80
Motherboard - Asrock 880GMH/USB3 AM3 ATX - $80
RAM - 4Gb G.Skill Ripjaw DDR3 1333 - $45
Graphics Card - HIS Radeon 6870 1Gb - $220
Hard Drive - 1Tb Samsung Spinpoint F3 HD103SJ - $60
Case - XCLIO Godspeed - $40
Power Supply - Rosewill V2-600w ATX12v v2.3 - $50
Optical Drive - LG GH24NS50 24x DVD RW Drive - $20
Subtotal = $595
Total (After tax 13%)= $672
These prices were taken from multiple online stores and averaged. The prices for these components were their normal retail price, not a sale price.
So it is possible that you could build this machine for much cheaper then the listed price here.
If you can get the budget get a Phenom II as they have L3 cache which will help with gamingThis is my final revision for this build. From the looks of everything this would be a solid gaming machine for about $650. I switched out the 500w Thermaltake for the 600w Rosewill and the Gigabyte mobo for an Asrock mobo. I kept the 6870 in there because the performance in DX11 games look to be better overall then the GTX460.
6870 can be had on sale for less than $220 if you look around. Put that towards a phenom II?
Rosewill is a crappy brand that I have heard bad things about... stay away from their PSU
What he said. Even if its a dual core phenom II. The majority of them unlock into quads anyway, and unlocked it will roast the athlon. If it doesnt unlock I dont think theres going to be much difference anyway.
