Hello All,
I'm building a new rig after several years and I'm hoping I can get some advice. I've done my due diligence, but I may have missed something subtle, such as the RAM isn't ideal for this mobo, or that the GPU won't fit with that case, etc. So, any help is appreciated.
1. What YOUR PC will be used for:
- Gaming and Work. I want the PC to be ultra fast, I want to load windows in seconds and I want to load my applications quickly. I want to support 4K gaming at 144Hz.
2. What YOUR budget is:
I'm looking at $10,000.00 with monitors, tax, shipping, etc... All in.
3. What country YOU will be buying YOUR parts from:
CANADA!!!
4. IF YOU have a brand preference:
No preference, but I want the case and components to be mostly white.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are:
Just my KB (Logitech), Mouse (Logitech), External HDDs, Headphones (Sennheiser), and smaller components.
6. IF YOU have searched and/or read similar threads:
Didn't find anything with these parts.
I don't plan to OC much, if any at all.
As soon as I can buy the darn CPU and GPU.
9. What resolution and settings do you use:
I'll be getting the LG 27GN950-B, so I plan to game at 4K at 144Hz. I'll reduce settings if my rig can't support 4K.
10. Are there any specific technologies you want:
My entire part selection is based on "what I want". For example, M.2 NVME, multiple USB ports, Gigabit LAN, Etc...
Please note, I'm okay to downgrade the CPU to 5900X and the price of the GPU on pcpartpicker is incorrect, I don't know why. https://ca.pcpartpicker.com/list/q3PGRT
Thank you in advance!
CANADA!!!
