Burnt RAM. Help!
santonel
Member
So I have an old computer that I use that has been running Ubuntu 8.04 fine for just over a year. I booted it up today and it gave me a kernel panic. Something like:
Kernel panic: not syncing - attempted to kill idle task!
So I looked online and people had success with switching the RAM chips. I thought of course since Ive had problems before because the motherboard was always very finicky about RAM. So I switched the chips and it wouldnt even boot. So I tried with just one and I got a red led on my motherboard followed by a burning smell. After taking the chip out it seems thats where smell is coming from.
So I have one stick thats presumably fried another one that presumably isn't. But I'm afraid to plug in the other one and turn it on for fear of the same thing happening. What should I do?
Specs are:
Athlon XP 2400+
Abit KR7A (KT266a) motherboard.
2 dimms of 256mb DDR333 Ram
Geforce ti4200
420w power supply.
Any help would be appreciated!
ImmaPC
Burnaby, B.C.
Well, you could start by getting new RAM, and testing that out. At this point if you've already lost a stick then I would try the other one as well, perhaps in a different slot.
What bugs me is that it could be a problem with the motherboard, like it's giving to much voltage to the RAM causing it to overheat and fry, but that could be somewhat unlikely.
santonel
Member
Ok so I tried with the other DIMM. Nothing fried but still no boot.
EDIT: Might have done something really stupid like inserting that other DIMM backwards when it fried:censored:
Perineum
Surrey, B.C.
Good question.
Take a really good look around the motherboard/RAM slot area. REALLY look. See if you can find anything out of the ordinary.....
If not then download and run memtest with the stick of ram that will boot.
I don't think there is anything else you can do.
santonel
Member
I don't think it will even run memtest. It doesnt even give me a video signal. No beeps no BIOS. Nothing.
Silvgearx
Toronto
so, were your PC overclocked when you booted ubuntu?
i get the same error with an overclocked P4. If you reset it to stock it should be fine.
From the looks of it you fried the northbridge's ram controller :ph34r:
santonel
Member
So I brought it to my friends house and swapped in some of his parts and it ended up being the power supply of all things. Its working now. Thanks for your help!
ImmaPC
Burnaby, B.C.
LOL! I was actually thinking of saying it might be the PSU but then I was really sketchy about it so I didn't! Well nice job either way, too bad that PSU went down and took a DIMM with it!
