Yes, the Internet seems to be quite upset about the price in light of the things they've left out!12600kf
16gb 3200 ram
1tb nvme (ps5 pro is 2tb)
Cheap case
650w psu
3060ti for $100 more can hit same GPU as PS5 pro
Actually not a bad value
Ps5 pro doesn't come with bluray player... for a console not sure that is a step I'd skip
There is a chart in the video. Ps5 and ps5 pro in no way are using 4k native. Using FRSS to hit 4k, so he did the same with 3060ti. And he can always toss in a newer card in a year. Ps5 is lockedYes, the Internet seems to be quite upset about the price in light of the things they've left out!
That 3060ti though... performance the same as PS5 Pro at 4K? Or is the PS5 Pro not advertising 4K?
Thanks Izerous. I've been pondering a bit more 4K power for my setup, maybe replacing my 6800 XT with a 7900 XT... but that is topic for another threadThere is a chart in the video. Ps5 and ps5 pro in no way are using 4k native. Using FRSS to hit 4k, so he did the same with 3060ti. And he can always toss in a newer card in a year. Ps5 is locked
And let's be honest DLSS out performs FRSS as it has had a whole generation headstart. Though I never use either. I happily hit 4k@60 with it off on the 7900xtx, and the 1080ti never supported it.
Having still not watched the video, I have issues with that setup. Its not like for like if you use garbage case vs PS5pro "nice" case, 1tb ssd vs PS5pro 2TB, and 3060Ti GPU vs ps5pro gpu (which current estimates say will be closer to a 7700XT (likely near a 3070Ti).12600kf
16gb 3200 ram
Cheap case
650w psu
