Can I run my board on one 4pin atx
Shadowarez
Folding Team
Arctic Canada
As title implies can I run my Asus sage 10g with just 1 4pin atx pin for the CPU it'll be a i5 7640x 4 core? Got a corsair 650 sfx on way but need test board see if it's functional.
Shadowarez
Folding Team
Arctic Canada
Ahh the board uses 6pin pcie I have a few 6pin to sata not sure that'd work. The PSU I'm usi g is 650 watts atm but think it only has a single 6 pin its not modular.
Cannon Fodder
Mission, BC
Now you've got me confused..... as the thread, that Lysrin linked to, mentioned, the CPU power should be 4 or 8 pin, so why are you talking about 6pin PCI-E, when you're wondering about checking the board with a particular CPU? o_O
Shadowarez
Folding Team
Arctic Canada
I'm miscounting the pins on this board I Beleive its the CPU power for this and if I can populate 1 instws of both and be ok until I get my other PSU in.
KaptCrunch
Ontario
Yes to can fit for the so called (square with 2 corners beveled) key fits in a square hole on MB
For I killed GPU over that CM didn’t mark the cables on PSU
You can see with coloured wires but were all black wires after with multimeter checked pin out found polarity was wrong
So if wanting 8 and only have 4 CPU power on PSU can re pin the PCI-e power to match MB power. if PSU has enough amps on the 12 volt rail you can do that other get proper PSU
Note: for 8 pin MB power is for crunching all cores an threads running full and server app’s
So no pci-e to power MB
Just check with multimeter to be sure correct pin out before connecting to MB
Shadowarez
Call Asus for looked at manual states 2 x 8 pin plug, witch is confusing.
so ask for the pin out for I know MB and PCI-e are different hate see you smoke a $grand
JD
Toronto, ON
This board has a lot of power connectors...
You might be able to use 4pin CPU power in the right most socket at the top of the CPU. I'm not sure it's advisable to run any heavy loads in that state though as you probably won't really be supplying enough power to the CPU. If you just need to quickly test the board functionality though, you might be okay.
The socket below the PSU looks to be for PCIe 6pin power, likely to give more power to the PCIe slots when running triple GPUs.
