Can this Really Lower CPU Temperatures?
Gav
Administrator
Folding Team
Canada
A simple, easy and cheap way to lower CPU temperatures has been something everyone looks for. Especially when it comes to lower ITX case temperatures. Now Noctua is launching the NA-FD1, a series of foam connectors that create a funnel between the side of your case and CPU cooler. Technically that should work but does it really lower CPU temperatures??
Izerous
Folding Team
Edmonton
I would have actually left the thick foam on the bottom and clipped it at the 10mm length. Then swap the foams around. The studs would have then been about 4mm short from the metal without and messing around but would have still be 6mm into the 10mm foam
