Cannot install western digital 1tb external hard drive
peter762033
Member
Hi, im trying to install my new western digital external hard drive. Firstly im running XP. Basically this drive is just plug and play so it doesnt come with any driver disks and the western digital website doesnt have drivers to download. Now when i plug the drive in windows recognises it and opens the hardware installation guide. It starts installing the hard drive but then i get an error saying that the hardware cannot be installed, also i then look in the safely remove devices area i can see the drive but it has a yellow exclamation mark next to it.
Ive looked in the device manager aswell and it says i have a code 28 error, now ive looked this up and it says the solution is to click the reinstall drivers button in device manager, i did that but i just get the same error message coming back. Ive tried the hard drive on a computer which is running windows vista and the drive worked perfectly so i know its something to do with my computer. Has anybody here had a similar problem?
Hope someone can help,
thanks!
peter762033
Member
Here are some screenshots of my problem, (had to post this in another post becasue i need one post to post image links)
thanks
peter762033
Member
ok ive gone into disk management, but im not sure how i initilize the drive, heres a screenshot of what i see when i right click the drive
Thanks for the reply much appreciated!
martin_metal_88
Quebec City
Right click on the disk 5 logo. If you see the option initialize press it. Then right click on the sector ( the blue line named new volume ) and press the option create new volume or something like that, follow the option and don't forget to press fast format or it will take all day. Don't forget to let it to NTFS or you wont be able to put files bigger then 4GB on it. After that it should work flawlessly.
peter762033
Member
Ok, ive right clicked the disk 5 logo but i dont get the initilize option i only get properties and help, is that normal? And i cant see create new volume when i right click the blue bar either :s, is there a way to get the initilize option to come up?
thanks
peter762033
Member
Here are some screens of what i get when i right click on both of them,
Is that not normal?
(oh and i just did another format so thats why its now called elements and not new volume, but it didnt resolve the issue)
Thanks
