Hey gang, having an odd issue that I'm unable to figure out. I just recently upgraded my CPU from a 3600 to a 5700X. I have an ASUS TUF Gaming X570 MB and 32GB (2x16) of DDR4/3600. BIOS is fully updated and I've never had any noticeable issues with the system. I've never OC'd the system, and I have so far run everything at default as I'm just too busy to tweak these days.
After installing the new CPU and confirming everything runs fine, I enabled DOCP in the BIOS and only see one profile, and it matches my RAM so I enable it and reboot. System fails to post and then flips to the message prompting to go back in to BIOS and reset to default. I tried bumping the CPU voltage to 1.3 (default is 1.2) to see if that would help, but it doesn't. This is frustrating as the default RAM speed the system is sitting on is 2134. This definitely seems fishy, but my experience with tweaking RAM settings for Ryzen is almost non existent so I'm not even sure where to begin with manual settings, or why it wouldn't be booting with the DOCP profile. I've done some googling, but information on similar issues seems to be pretty outdated as everyone seems to have no issues with DOCP profiles lately. Digging for manual settings for RAM yields more results, but the advice ranges drastically and isn't all that helpful. Any input from a trusted community would be welcome.
MB: ASUS TUF Gaming X570-Plus
CPU: 5700x
RAM: 2x16GB DDR4 3600 GSkill Ripjaws V - CL16-19-19-39 1.35v
*EDIT* Images added
CPU: 5700x
*EDIT* Images added
