cant plug in front panel usb and firewire?
go flames go
just want to make sure on the p6t deluxe mobo when using to video cards blue and white slots you cant plug in the front panel usb and firewires.
rjbarker
Courtenay, B.C
Really....?......no?!........if so glad I didn't go with that design!!!
Dwayne
Courtenay, BC
Are the headers circled in this pic?
If so, why would you not be able to hook them up to the front ports?
Dwayne
Courtenay, BC
I would think that you would be able to connect the front panel connectors first then install the GTX 295. I think all that would happen is the shroud would push down on the already connected headers... just don't use the Asus easy connect thingies.
go flames go
nvm! problem fixed i diddnt push in the headers hard enough once they go all the way down the cards fit no problemos!!
Realityshift
Fort McMurray, AB
I was wondering what was going on with this, most Tri SLI boards have headers in the same location vs bottom PCIe slot and ive never had troubles with the headers even with dual slot cards in the bottom slot.
