Can't Select SSD for OS Install
AmuseMe
Saskatoon, SK
Wanted to do a clean Windows 10 OS reinstall on my laptop. I have a 256GB SSD (boot drive, select software, etc) and a 1TB HDD. I wiped both and reformatted. They are both recognized in the BIOS, but when I get to the step where I select the install location for the OS, there is no SSD. I can install the OS onto the HDD and then see the SSD from DSKMGR.
What am I doing wrong here?
JD
Toronto, ON
Is it plugged into a different SATA controller that might need a driver?
It could also be poor formatting. I'd suggest the following from an Admin CMD window:
Code:
diskpart
list disk
(find the disk number of your SSD, using it in the next command)
select disk [I]x[/I]
clean
exit
Or you can run these commands while your on the page that asks you to select your disk during the Windows install by pressing Shift+F10 to bring up CMD prompt.
AmuseMe
Saskatoon, SK
Code:
diskpart
list disk
clean
exit
Only shows up the HDD and the boot USB. No SSD in the command prompt. Must be driver related. I'll proceed with that. Thanks JD
