Ok, that explains the "loud" when you select "PWM". 3 Pin fans run @ 100% when PWM is selected. I'm not sure what your options are for the individual headers, but they should be set to Voltage controlled if you have the option.
ill have a look in a bit but im pretty sure the voltage modes i have are PWM, DC and Auto. the fans are currently set to autoOk, that explains the "loud" when you select "PWM". 3 Pin fans run @ 100% when PWM is selected. I'm not sure what your options are for the individual headers, but they should be set to Voltage controlled if you have the option.
ill give that a try, appreciate all the helpDC then. That will eliminate any issues the board might be having with determining what kind of fans they are.
turns out the other mode was voltage and switching it to that did not fix the problem. also turns out i can start the fan manually by spinning it. pretty bizarre lolDC then. That will eliminate any issues the board might be having with determining what kind of fans they are.
not sure how to do that in the bios but ill give it a try. fans shouldn't be cooked cause they are like 2 weeks oldSet the fans to 12V. If you can get them spinning and they stay spinning then work your way down in voltages to the point where they are quiet enough for you, or stop spinning.
If they don't stay spinning then they are probably cooked.
