Case for first time build
Dragonstongue
Brockville, ON
N600, Antec P100, Corsair 300r, Arc Midi R2. P100 is what I am planning on getting for myself a very slick design with quite good cooling and many options no matter what you want to do really.
Dragonstongue
Brockville, ON
and FYI if it has internal usb to rear usb type thing, usb 2.0 can feed the 3.0 slots though of course not same speed or power out but will work, best bet is headers wise and best period are the ones that have 3.0 and 2.0 capable so no matter what case you use it will work but very few cases do this, and even more motherboards do not have the full 3.0 header size either most still rely on cable out back to rear panel type :(
tzinck11
Member
Thanks for all the replies, what would you guys suggest for a cheap power supply for this build?
