Case Pics
Patriote
New-Brunswick
Very very nice and clean rigs patriote and lowfat! Can't wait to join you guys in the big tubing club.
Patriote, looks like your rad's fans are pulling air wouldn't it work better if they were pushing ?
Uh...Negative sir! Rad needs cold air from outside the case for better temps!
Or are you saying that fans should be pushing through the rad instead of pulling through it ? If so then there is no difference between both set-up.
SHaCK
Montreal south shore
The later :biggrin:
Off course it wouldn't be possible with your setup, you'd have to mount the rad outside the case I guess.
Babrbarossa
New Brunswick
How thick is that thermochill rad?
I see you have the tygon tubing so you obviously think it' worth the extra money over clearflex. Other than durability, what other advantages have you found?
Patriote
New-Brunswick
It's the thickest rad available. You can find the exact measurement on Thermochill's website.
Yes, i definitely think that Tygon is worth the extra money. So far i have tried Masterkleer, Clearflex, Swiftech's cheap one, Primoflex and Tygon.
Tygon was the one i liked the most to work with. It also was the most crystal clear i found and wasn't actually some of that cheap PVC tubing i tried which isn't that good.
M
Misoprostol
Guest
IMO Tygon is definitely worth the money. It doesn't kink like masterkleer, it doesn't flatten like Clearflex, and it'll last longer. You can reuse the same Tygon over and over again if you're a little bit creative about how many times you cut it and plan to conserve it over time. It's much easier to get clean than Clearflex too.
Patriote
New-Brunswick
Nice to see someone agreeing with me on that point! :bleh:
Babrbarossa
New Brunswick
water cooling and case mod
Here's a preliminary pic- still a little cluttered in there (probably shouldn't have put that t-line in either but it'll help with draining)
Still waiting for more smart coils back ordered- I don't really need them on the rest, but I think it looks better if all the hoses are done.
Patriote
New-Brunswick
Looks good Babrbarossa!
A little messy in there but i suppose it's just normal with a P180 :bleh:
So thats your first WC build right ?
Oh and yeah that T-Line is (IMO) useless. Draining isn't that hard. Well, it never been with any of my set-up.
Babrbarossa
New Brunswick
yeah- it'll overclock to 680MHz cpu, and 1000 mhz memory- Not surprisingly, I was able to increase the gpu from 600 to 680, but I don't think I can get any more out of the ram - The passive cooling doesn't help temps there, I guess.
Temps for the gpu never seem to go above 43 at load.
I'm surprised at how close the idle and load temps are for cpu and gpu.
